Phoenix 3.12 Output Path Problem when simulating on Blades with deadline ! Falling back to default. //
Hey Guys
unfortunately we have a problem with the 3.12 version of Phoenix.
local all the simlulation works just fine but when i submit a sim over deadline to a renderblade, all cacheframes are getting stored localy on the blade.
The maya script ed shows this error while submitting:
// Warning: Phoenix FD: Invalid cache path specified `/media/CX_VFX/_INTERN/FELIX/phoenixFD_Test/data/`! Falling back to default. //
hopefully one of you has an idea.
We are working with Maya 2018 &Phoenix 3.12
Thank you in advance
cheers
Felix Brosche
3D Artist
Hey,
The error message comes from the Global Preferences dialogue. Check if your path there is valid. Mind that it’s a setting specific only to a version of Maya, only on that machine. Maybe you are submitting to a machine that has this path override in the preferences and this is why it can’t find your submitted caches?
Cheers!
Hi Svetlin,
true, but even with the correct path in there it is doing it.
Just found that workaround.
This is my Path inside Maya : media/CX_VFX/_INTERN/FELIX/phoenixFD_Test/data/Test_####.aur
This is the path which deadline is creating : /home/chromatix/maya/projects/default/media/CX_VFX/_INTERN/FELIX/phoenixFD_Test/data/Test_####.aur
With the slashes i am getting rid of the unnecessary parts of the Path /../../../../../media/CX_VFX/_INTERN/FELIX/phoenixFD_Test/data/Test_####.aur
cheers and happy new year :slight_smile:
Ahhh, so “media” is not a mapped drive, but a relative path. I don’t think these would work in the Phoenix plugin - there is only support for relative paths when rendering with vray.exe through vrscene files.
Will double check and add a TODO item for implementing relative paths.
Actually it is an absolut path. I forgot one slash here : /media/CX_VFX/_INTERN/FELIX/phoenixFD_Test/data/Test_####.aur We are working on CentOS 7, so ´CX_VFX is our main drive.
Cheers
