Phoenix 5 Candle Sim Issue
Hi everyone,
We seem to be running into an issue here with all of our candle simulations in Phoenix 5 using Corona. We’re are simply trying to add a candle simulation to our scene but whenever we render it, either the flame gets cut off or it is being stretched. We’ve tried increasing the adaptive grid and adjusting a few other values but whatever we do, it still remains distorted - even with default values using the “setup a candle sim for the selected object” option.
I’ve attached a link to some images that shows what I mean - you can see that in the viewport the candle appears normal but when you render it, the flame is extremely stretched:
Does anyone else have this issue?
Many thanks in advance for you help,
Michael
Which version of Corona, which version of Phoenix, which version of Max?
I believe it’s Corona 9, Phoenix 5 & Max 2023 :wink:
Hi, please submit a new support ticket here: https://support.chaos.com/hc/en-us/requests/new
Then share your ticket number here. We will make sure that Corona team + Phoenix team assist you together. :smiley:
Thanks for the speedy feedback guys!
Beanzvision - you have impressive inference skills! :wink:
Thank you Maru, I’ll create a ticket now!
Edit:Ticket number is #110557
Appreciate the help.
(sharing this in addition to the support ticket)
I have discussed this issue with one of our Phoenix gurus and here is the explanation:
Due to the way Corona currently handles volumetric opacity, the candle simulation will render differently in Corona than in V-Ray, even with the default setup.
In order to match the render result to the viewport preview in your case, you can:
  • Select your Phoenix object, go to its Rendering rollout, click “Volumetric Options…” and in the pop-up window change “Fire Opacity Mode” to “Use Own Opacity”.
  • Then use the Curve below to adjust the flame appearance to your needs
Here is a video showing the steps : http://ftp.chaosgroup.com/support/scenes/3dsmax_2023-04-28_14-54-37.mp4
I hope it helps! Please let me know if you need some further assistance.
Maru, you’re a legend!
This is fantastic, thanks so much for also providing a video on this too, really appreciate it! I’ll give it a go now!
Thanks again!
