Phoenix FD and Deadline (via maxscript)
Hi guys, I hope i will find some help here.
I’m trying to build a tool for autocaching and submitting Phoenix simulation to the farm using Deadline.
I did a search on the forum but i still have some trouble with my script. ( I’m not an MAxscript Expert …)
The autocache part works great, phoenix is really easy to control via maxscript !
Right Now when I’m sending the jobs, it just Load, and finish in like 1 minutes without sim anything.
Drive are on network and i use deadline all the time so i’m pretty sure the problem isn’t here.
What Command do i need to use ? I read on the forum that i need to use the command A_wait but I don’t know how to use it.
Here is what i’m doing : ( simplified)
-- Autocache if needed
-- Loading Deadline Script
-- Collect Phoenix grid as PFDgrp --
for obj in ($ as array) do
        if classof obj == liquidsim or classof obj == firesmokesim do
            append PFDgrp obj
rendSaveFile = false
        renderscenedialog.close()
        vr = renderers.current
        vr.output_saveRawFile =false
        vr.output_on = false
-- the tricky part :
        if classof $ ==firesmokesim or classof $ ==liquidsim do
A_startsim (PFDgrp)
                A_wait (PFDgrp*) --???*
--and that’s all ??
-- Sending the job to deadline.
I hope all technical artist will enjoy my noob coding skills haha.
I’m using the last PhoenixFD nightly
BTW i found Phoenix really good ! Awesome piece of software ! i’m a happy new user.
Cheers
Cédric
i think it should be A_startsim $ , because you are testing $ to be a simulator
a_wait $ is needed only if you have more than one simulator, because you can’t simulate multiple simulators simultaneously
Thanks Ivaylo, i will give it a try !
Good to know for the a_wait $ command
