Phoenix FD backburner sim hangs at 'Starting GPU engine...' on render server if V-Ray GPU Next is the selected renderer when queueing job
Hi all,
I’ve had this catch me out a few times with several files recently, will double check settings to make sure I’m not doing something stupid or see if I can track down any more info.
If I have V-Ray GPU Next selected as the renderer and queue a Phoenix FD sim via the Submit Simulation to Backburner menu, the job submits ok and is picked up by a render server but doesn’t start processing frames and hangs at ‘Starting GPU engine…’.
If I set the renderer to V-Ray Next and submit the sim, it processes as expected. FWIW the same scenes render fine with GPU Next, once the sim has been cached.
Max 2018
V-Ray Next update 3.1
Phoenix FD 3.14 Build ID: 20190427
Backburner 2018.0.0.3005
Thanks for any help!
Jon
Hey,
Thanks for the report, this is a known issue and it is already fixed in V-Ray 5.
Unfortunately as the code has changed quite a lot with the time it will be extremely difficult to backport the change to V-Ray Next.
The issue happens when submitting Phoenix simulations through Backburner and V-Ray GPU is assigned as a renderer. Rendering should be working correctly.
As a workaround, switching to either V-Ray Next CPU or Scanline renderer should simulate without issues.
Hey Georgi,
Thanks for the reply, good to hear it’s a known issue and has been sorted in V-Ray 5, hopefully I’ll be upgrading sometime soon.
Cheers,
Jon
