Phoenix FD Compatibility
It would be great if Corona could render Phoenix FD particle shaders, at least the basics like point. Currently it’s possible to render Phoenix meshes, but for water sim with foam, splashes, etc, the point particles are rendered but only in black, there is no way to change the shader, material or settings or color.
Soon there will be proper Corona rendering though, and Octane are also on it.
ref. link:
http://forums.chaosgroup.com/showthread.php?89987-render-PHX-alembic-as-fire-and-smoke&p=708186#post708186
I hope this is coming relatively soon, volume/particle rendering is one of the few things i cannot do in Corona, but if i could i would and there would be no need to use Vray anymore.
there should be a bugfix related to phoenixFD in latest daily, can you try if the support is improved?
