Phoenix FD Fluid Not Rendering in Maya 2020- Vray Default Settings?
Hello! I created a scene, dropped in a “tap water solver” and a plane. Did a quick simulation and hit rendering and my fluid is not showing.
Here is a link to the scene file: Dropbox - Error - Simplify your life
There is nothing special about the scene and I have no idea why the fluid is not rendering. I would appreciate any help I can get.
Do you get any errors or warnings when you start the rendering?
Can you attach the logs from Phoenix and V-Ray. This article will help to find them >> Phoenix for Maya
What OS you are using?
No issues with the setup or rendering in a quick test here.
I just had to restart Maya for some reason but that fixed it. There were no errors or anything… basically nothing happened when I hit render.
