Phoenix Fd foam
Phoenix fd FOAM is still not working (in release candidate too)???
There is no API for foam from Phoenix FD, so no way to “bind” to it. Either the Corona team or the Phoenix team will have to create an API, which is a big task, and won’t be done as part of the Corona 2 release, sorry.
I know this, you said this a long time ago, but nothing has changed since then. So, to say that Corona supports Phoenix Fd is not correct.
What I want to know is whether the Corona team will take the effort to correct this error or not???
So if this error will not be corrected. I can start thinking about moving to Vray or finding another solution.
Correct, it’s a big task, and big tasks take a lot of time (and take fitting in to the other existing work). The current support for Phoenix FD is well-described, and notes that Foam can’t be supported as yet. As with most things, future improvements can be expected, and will appear on the roadmap whenever there are plans and timelines in place for them!
I agree with the previous speaker, without the support of foam, I do not have a sense in version 2, since the main work of the court on the water, will have to stay on vray, is there at least an approximate time for foam support, 2018, 2019, or can it drag on? did not even see this in the road map. :frowning:
News???
No news at this time - you can see the plans for what we’ll be working on on the roadmap https://trello.com/b/EfPE4kPx/corona-road-map-3ds-max
Wetmap Is working in Corona?
BUMP
Okay, I’ll tell you … it does not work either!!!
Hello, we will definitely ping you once we know when we can support foam. As for other features (materials, maps, etc) we will compose a list of supported features so far.
We are sorry for your inconvenience.
Any workaround about using Phoenix Splashes with Corona? :smiley:
Any news about wetmap with Corona and PhoenixFD?
Will foam support be implemented any soon or should i start to look for a workaround?
Yeah I would love to know, too.
same for me
If it were in the plans, it would be on the roadmap, Trello - so, nothing in the plans at the moment, sorry.
