This sometimes work and often does not.
Make a Phoenix FD liquid sim. Render one frame and everything looks fine.
Render a sequence and Rt only renders the starting frame of simultion on each frame.
I’m pretty sure i had this issue with pflow too.
Something i’m missing?
Hey, is it possible for you to attach a scene where this happens? Couldn’t reproduce the issue with any of our test scenes, so must be something specific to the scene or settings that causes it.
Hey, the fix is in today’s V-ray 3.0 nightly, and you need today’s phoenix nightly too. If you don’t have access to the nightly builds, a workaround will be to disable “Show mesh” in phoenix’s “preview” rollout. Actually this option was taken into account for RT rendering, which was wrong. Now only the “Mode” option in the “Rendering” tab controls the render mode.
Thanks for the report!
