Hi Everyone,
Can someone please tell me if I can increase the icons size of PhoenixFD menu in 3DMax 2021. I have o 4k screen and I simply can’t see the icons, strangely there’s no issue with Vray!!!
Hi Everyone,
Negative, unfortunately you can’t increase them. Our artists gotta prepare high-res icons for Phoenix as well, but it might not happen very soon.
Cheers!
OK, can you tell me where the icons are located?
Yep, they are in C:\Program Files\Autodesk\3ds Max 20XX\UI_ln\IconsDark, or Icons if you need the light theme. Maybe if you resize them, they will load correctly. The files are 4 bmps starting with “Phoenix”
Cheers!
Hi, I went in to the folder and there was to size icons 16 and 24, aren’t the 24 a bigger size that can be loaded and increase the size of the menu like in the other toolbars or do I need to rescale even further?
How much should I increase…because I really don’t know the size for the 3d system?
