We are currently evaluating Phoenix FD for use with some water features. I know Corona doesnt support the foam feature but does that also extend to the splashes feature which is in a separate roll out? When we come to render we get a Corona warning saying Corona doesnt support foam but we thought that was a different thing to splashes? We havent done any special set up in corona to materialise the splashes or in phoenix so maybe we need to do something there? Corona looks like it supports other particle effects in Phoenix so I’m hoping its just a set up issue.
AFAIK Phoenix uses the same particle shader for foam and splashes, so both are unsupported. We will check it and get back to you with a definite answer.
