hey
i’m playing with phoenix for couple of days and i got big problem with rendering simulation, im trying to generate dense smoke from object which is moving, and when the new voxels are generated on surface, they simply flick, is there some easy way to get rid of it?
there is no visible reason for flickering, so i would bet for the displacement texture.
beside this, i would recommend to optimize the simulation settings. disable the temperature export, use simple smoke for the transparency, use uniform density simulation. and the most important - select you best settings in a small grid, and then move them into the bigger grid. i mean small by cell count, but with the same cell size in the same scene. if you change the cell size, you will obtain different results, due to the gravitation.
try to use symmetric conservation, in my opinion it is better for smoke sims.
and one more direction for experiments - fixed spf mode. this means, set the advection step to a big value, let say 50, and set equal value to both the upper and lower spf limits, start to experiment with 1. this may produce better and faster results compared to the default settings
