Phoenix for maya fd field
the phoenix fd field bug the simulation.
the smoke rise normally when the fd field is not connected and as soon as u connect it it get frozen, the smoke and temperature are still emitted but don’t rise anymore.
the source is particles, they emit smoke and temp in a volume, another set of particles is supposed to be driven by that fluid.
Can you send me the scene - ivaylo.ivanov at chaosgroup.com.
i copied the file there
http://dl.dropbox.com/u/2025548/debugPhoenix\_FDField.rar
thanks
You must disable the interaction between the Phoenix field and the simulator. This is not done automatically and you get this strange effect. Aside from this, I’ve found a bug related to the time scale calculation, so for now use the “Ignore Time Scale” option in the field attributes. This will be fixed in the next nightly/beta.
where do i disable the link in between phoenix field and the simulator, i can’t see any in the hypergraph, or the fdfield ?
See the Interaction section. There is a set called phxsim_set1. By default it excludes objects from the simulation.
