Hi Svetlin,
I know you are mad and angry at me that I respond to this again and I suppose to not understand how things work in Phoenix.
You are totally right. Im new with Phoenix !
I already repeat this many times and I started a new scene and actually you can make the test yourself.
As I already said - I did already create this issue 3 Times and any time is the same result. So I cant tell you what is wrong.
You can have a look into the video under the link below - “All file sources under” .
The file contain also the files which I use to create the last test for the video. The fourth test.
For the discharger file please understand what I mean with XYZ Axis System in MaYa
and not
XYZ Axis System from 3ds max.
The YZ Axis for the “Position Discharger” in the Phoenix Sources are exactly the 3ds max Axis System.
I didnt tried the other ones, but I guess is exactly the same !
All file sources under:
https://www.class-a-strak.com//XBO/C…OBLEMS_BUG.zip
Side Note:
I understand as a developer that get enough of a new Guys, but even if Im new before I post something anywhere I do a EXTREME research.
I dont spam or open threads just like that.
The other test with 5 Emmiters and 5 Sources I didnt make it.
It is a lot of testing and Im not a beta tester or Chaos certificated tester.
I just share the problems I have in my situations.
As you can see I did a lot of tests. (Simulation test, applying test, rendering test, etc…)
OH BTW!
Why if I change the name of my Sources (Boxes) will just add new “Particles of Particles” instead of deleting them.
It can be a huge unused library of “Particles of Particles” (You will see a situation in my example where I change the name from Box_01 to Box_01___NAME_CHANGED).
Wile I change the name to my sources then I need to reconnect them again, because the “Particles of Particles” are connected to the name before.
Ah… you will see in the video.
It becomes really complex and understandable.
Is there a way to delete via script in a Window where I can see all the “Particles of Particles” in my scene so I can delete all the unnecessary “Particles of Particles” ?
