Phoenix Simulation Jump
Hi, I have some problem here. The simulation jump every 15 frame. It is seem push inside a little.
like this the 60 frame push inside.
Probably you have Motion Blur enabled in the settings of your renderer, but Phoenix FD has missing Velocity channel and renders with motion blur only in the Backup frames. Make sure that you have the Velocity channel exported in your Output rollout.
The other thing that could cause that is the Mesh smoothing option “Us Liquid Particles”. Make sure to check our FAQ section here - Chaos Docs
I would recommend getting a latest nightly build as well - as they contain quite a lot of fixes and improvements. You can find more about it here - How to get Nightly Builds - General - Chaos Forum
Hey,
Yes - using the second method will export the velocity channel for both the particles and the grid.
