PhoenixFD maya 3.10.00 is different result from YouTube tutorial video.
I translate Basic Liquids QuickStart.
The scene using Tutorial Assets in PhoenixFD maya 3.10.00 is different result from YouTube video. (Water jumps out of the bottle)
Where do I fix the same result
We’re currently looking at it.
Cheers!
Hey,
So the behavior is normal. After a bunch of bugfixes since the tutorial was made, this is how the liquid should behave. You can try a few things:
- Move the emitter down. Right now it’s too far up and the liquid accelerates too much.
- Make the emitter smaller. Currently it’s too large and emits a lot of liquid which splashes hard against the goemetry.
We will edit the tutorial and the attached scene.
Cheers!
thank you for the advice.:slight_smile:
I will write it as a note.
