PhoenixFD Particle Age from Houdini
I’m trying to export a whitewater particle sim from houdini via PRT. All is working, except that i cannot seem to get phoenixfd to read the age attribute. I tried several naming attributes: age, pa, age_pa … nothing works. What’s the name of the attribute that phoenix is looking for? Also is it a simple float?
All the other attributes are reading fine.
Also, i’m using PRT because it’s the only way i know to import particles in phoenix, however, i would like to ask if there’s any chance to use alembic and still use phoenixfd to shade the particles?
The channel is named “Age” and the type is float,
Hope that helps!
Cheers,
Kostadin
