Phong shading problems?
Hello everyone
I am having a bit of a problem solving this one. Dont know what is causing this… have a look at the image and files attached. If rendered with c4d render the look is as it should, corona looks like is messing the phongs shading.
This never occurred to me it’s kind of weird.
thank you
problem.c4d (281 KB)
I’ve get this problem yesterday with a small scale noise shader.
It renders clean here, 19.024 and the corona beta from November 3. What corona version are you using?
Hi
I am running corona beta September 5 on c4d r18.
Perhaps it’s a bug from that built, don’t know… I have to try the latest built and hopefully will solve.
There were some phong issues in a / previous version(s). So chances are good you can solve your problem with an update. Good luck!
Works fine in latest build.
Yes, the problem was due to my corona version. updated to the latest and all is fine now :wink:
Thank you all
