PHOTMATCH NEWB HELP
Hi
I’m new to vray but Ive been using Sketch-up for about a year. I don’t know how to use the photomatch option in Sketchup. Everytime I upload an image with photomatch I don’t see the image at all.
I’m trying to match this image that I merged from photoshop and add my new part of the building on top of it.
Can anyone help me?
Here is the image.
Re: PHOTMATCH NEWB HELP
when u opon ur photomatch edit menu theres an option that allows u to turn off the photo and the model… perhaps ur photo tab is turned off?.. and they suggest u use un cropped photos for ur photomatches… just a thought
Then you project textures on objects(like back-planes and ect) using photomatch add-on:
you can see new(appeared) material(contains matched photo) in sketchup mat.editor. so need ONLY manually reload this photo(image) again. You get normally matched objects(in render) ohh need to adjust camera…
Such techincs use kerky-exporter(3.0) and skindigo…or then try to export to obj, you can see uv-devided pics in texture dir.
