photometric light setup for amimations
i am rendering an animation and i have about 50 photometric lights in my scene. The lights all use vray shaddows. the anmation is taking forever.
do you guys have any suggections for me… i ran the irmap at every 50th frame and saved it.
now i am animation the animation with the saved irmap at every 1 frame.
it is taking about 5-7 mins to render each frame…
help
IMHO 5 to 7 min is pretty fast for a GI animation with 50 lights, You can try lowering the subdivisions on the shadows a bit also if you are using area shadows it will render quite a bit faster with normal vray shadows. Or you can even try it with shadow maps.
Re: photometric light setup for amimations
Good luck
Gonçalo
goncalo,
any suggestions???
Well, with 50 photometric lights better going with radiosity…
Gonçalo
Or if you can calculate the GI without them, atfter that you can use them for the final animation using the irradiance map from file, but to calculate the irradiance map… its a lot of lights
Gonçalo
it’s a night rendering so the scene is dependant on the photometric lights… i will try to exclude them from the GI calculation and see what happens.
Just a though,…If you have the idea of the lights shape, you can model it and use this as the main light, applying a self-illumination material to the object and then hide it from the camara. This should produce fast renderings, and after you have the final irradiance map you can turn on the photometric lights.
Gonçalo
If you’re just looking for a good image, aesthetically, another technique might be to set up lights as if it were a photo shoot (three point lighting, VRayLights for softboxes or whatever). Use this to calculate the GI then render with the “house lights” for the final.
Just a thought… ignore if you need accurate lighting.
--Jon
