I’m rendering a short animation of an interior scene with both camera movement & an object moving. I’m using a stored photon map as part of the lighting. I’ve rendered the background seperately and now I’m rendering the moving object with all other objects as a matte material, vray light material objects are not visible to camera along with the vray lights. I am calculating an individual irr map for each frame. When I render the image as a tga with an alpha channel all the objects are visible as varying shades of grey in both the alpha channel & the image. All I want to get is the moving object & it’s shadow.
Is this an issue relating to using a photon map? I tried recalculating the photon map with the matte material applied in the scene and max crashes every time. We’re using Max 7 & Vray version 1.45. Here are the matte material settings.
That didn’t work, but I have figured out a way of sorting it out. I have a target direct light in the scene and when I exclude everything except the moving object from the light and my problem is solved.
