Hi guys, the thing is, im working with exr´s saved as 32 bits images, and im using photoshop camera raw to make some adjustments, but the moment i open the image is fine, and when i open camera raw “filter” it burns it, and if i lower the exposition inside camera raw it dosnt return to the original state.
So is it some color profile or something i need to change or what??
Could you describe step-by-step what you are doing?
Are you loading the file into camera raw using the “open as…” option? (I’m not sure what’s the workflow in newer versions of PS)
Hi Maru, im opening the exr image by double click on it, then i go to filters and camera raw.
And inside camera raw the image gets burn
Try this:
http://blogs.adobe.com/pselements/open-jpeg-files-in-adobe-camera-raw-in-photoshop-elements/
(just use regular photoshop instead of elements and your exr instead of jpg
, I’m not sure if it will make any difference though)
Ok, you are probably right. My bad. I also found a suggestion to convert exr to tiff first. But I’m not going to talk about something I have little idea about any more. ![]()
