Photoshop Plugin reading rpf files ?
I wonder if there is some, and if so, is it available for free ?
Someone did write a reader, it’s free but doesn’t support 16bit channels I believe, check the adobe forums.
It wouldn’t matter, 'cause I rarely use 16bit accuracy. It would spare my company buying combustion just for standard still’s production purposes. I’m going to check it out, thanks rhino!
I could be wrong, but I am sure there were some optional ‘plugins’ on the Photoshop installation CD-ROM that include an rpf reader (or was it rtl?)
There is an RLA plugin on the Photoshop 7 CD.
Alternatively, go to MAX Plugins.de - the plugin database for 3ds Max & search for XRLA. From the blurb:
“This is an import plugin for Photoshop 6 that can open Max RLA files with the Z-Channel being read in as a second alpha channel. At the moment it is not possible to save RLA files with this plugin, and it doesn’t work with 16Bit images.”
Hope this helps
Dave
If you are looking for a way to get G-Buffer stuff and mattes for use in Photoshop a commercial PSD exporter could serve you well too. Atleast much cheaper than a seat of combustion.
Daniel
