Photostop CC(2015) clamping .exr files
I made some custom HDR skies today. When I did my test renders the light intensity was waaaaaaay off. After some poking around, I found the problem. Photostop CC(2015) is reading and saving EXR files wrong somehow. Photoshop is clamping everything over +16.41 intensity down to +16.41. I’ll post some of my test results bellow so you can see what I’m talking about. My workaround right now is to save stuff as .hdr. I just wanted to give you guys a heads-up so you don’t clamp your images, save as .hdr from Photoshop.
I have tried every exr compression method, same result.
For this test I made a HDR of Corona Sun/Sky, 7070x3535px.
Real Corona Sun/Sky
HDR saved from framebuffer as EXR
HDR saved from framebuffer as HDR
HDR re-saved from Photostop CC(2015) as HDR
HDR re-saved from Photostop CC(2015) as EXR
Look at this shit, terrible.
Here are the values when you save from framebuffer or save from Photoshop as HDR
Here are the values when you save from Photoshop as EXR
Actually I think this is related or the same as the issue I posted the other week.
Are you using Contrast > 1.0 in your Tone Mapping? Doesn’t matter if using CoronaCameraMod or just the VFB. Because if you are, it will clamp your image no matter if you save to EXR 16/32 whatever.
The only “solution” is to use Contrast = 1.0.
Try that and let us know.
I always render 1-1 linear in framebuffer and use tone mapping as my last node. But as you can see from the color picker images above, this is not Corona related.
When I open a fresh .exr/.hdr the sun is +20 intensity. After a ctrl+s the .hdr is still +20 intensity and .exr is +16 intensity.
I even did a full format on one of my PCs and installed Photoshop, same result. It’s like Photoshop is corrupting everything above +16, because some programs read the new +16 value as 0.
I have uploaded a test for you guys. Open that .hdr, save it as .exr, close everything in Photosop and open the .exr again. The +20 value should be +16.
Test.hdr (30.1 KB)
I think you should post this on the adobe forums and see what response you get from Adobe on this. Looks problematic!
Yes, HDRs in Photoshop are handled differently than EXRs, up to a point where you simply can’t paint over a hot pixel in both positive and negative values, it’ll simply stay there and keep it’s value no matter how hard you try to paint over it. As for their support, I guess HDR images are not high on their list.
Have you tried with all of the available EXR save options - integer, full and half float?
I just made a post over at Adobe, man is that site a mess to navigate.
Could you guys please try to resave the test.hdr image I uploaded in my last post, and see what the results are ?
The image was made in Photoshop, so we don’t drag Corona into this.
It’s not only photoshop’s problem. I did quick test with Picturenaut and it clips dynamic range when saving to exr too. Maybe it saves to half float rather than full float?
