I’m a rookie when it comes to scripting but I’m creating some tools and I need to expose the properties of PHXSource.
Normally I’d type
show $
And I get the properties of the selected object.
With Phoenix I get
No Info Found on: PHXSource
OK
Hey there ! Most of the scripting parameter names are available in the documentation right next to the UI version.
For example : Mode | animmode - Chooses between different options for animation control.
Not sure if that’s any help. Hopefully Svetlin will chime in tomorrow with a better answer.
I can get most from the macro recorder but not the Emitter Nodes
Hey,
Using a latest nightly I can list both the Fire and Liquid source’s params using show $. Are you using an older build or a specific setup?
As Gosho said, most parameters on docs site also show the script names: Chaos Docs
Which parameter are you trying to access?
Cheers!
Hi Svetlin. Thanks and gah! now it displays what I was expecting.
I was on the hunt for .sources : node array
You are the best support ever!!
show $
.discharge : float
.temperature : float
.smoke : float
.rgb : point3
.fuel : float
.velmult (Velocity) : float
.usedmap : boolean
.usetmap : boolean
.usesmap : boolean
.useuvwmap : boolean
.useflmap : boolean
.uset : boolean
.usesm : boolean
.useuvw : boolean
.usefl : boolean
.usevel : boolean
.dmap : texturemap
.tmap : texturemap
.smap : texturemap
.uvwmap : texturemap
.flmap : texturemap
.timebase : integer
.iconsize : float
.pick_ph : boolean
.ifnotsolid : integer
.prttype : integer
.mtl_index : integer
.partsize : boolean
.useprt : boolean
.particles : float
.useprtmap : boolean
.prtmap : texturemap
.prtlife (Particles) : float
.prtlifevar : float
.prtexportid : boolean
.prtexportage : boolean
.liquidmode : boolean
.noise : float
.velmul : boolean
.smxvelthr : float
.prtxvel : boolean
.prtxvelthr : float
.prtsphsz (Custom_Size) : worldUnits
.prt_shape : integer
.dmoddisch : node
.dmodt : node
.dmodsm : node
.dmodfl : node
.dmodrgb : node
.dmodprt : node
.dontask : integer
.dontshow : int array
Yay, glad it worked out! ![]()
