Physical Camera causes jitter when rendering
I have a fairly simple scene with an flying aircraft (linked vrscene), a few constraints and a tracked camera from Nuke.
When viewing the animation in Maya, everything seems to be fine.
But when rendering the animation jitters back and forth and also triggers more motion blur.
I tried baking all animation or rendering proxy geo instead of vrscene. But I nailed it down to the physical camera attribute. When turning it off, everything renders fine.
Also the jitter seems to jump in at frame 140. Everything before seems to work fine. Weird…
Those little bugs really keep driving me crazy…
Using Maya 2020.2 and Vray Next (nightly build 20200914)
I rolled back to NEXT update 2.2 (Apr 28)
Still the same behaviour. Jitter with Physical Camera on.
No Jitter when off.
The Center of Interest is not part of the VRayPhysicalCamera Attributes and I am not sure that this is related to V-Ray. Is it possible to test this with different render engine as well? Meanwhile, you could set up a test scene and send it to support@chaosgroup.com so we could further investigate this. It would be helpful if you could give us more details on how you have created such a camera.
Hey Nikolay,
thanks for looking into this. I’ve sent a scene with two cameras and the respective render tests. I couldn’t send the assets visible in the renders, sorry about that. The camera has been created in Nuke via the Camera Tracker node.
Let me know if you are able to re-create the problem.
Cheers,
Vittorio
Hey Nikolay!
I didn’t try it with another renderer. In the meantime i recreated the scene from scratch, and the issue was gone.
I can prepare the scene for you on monday, when I’m back at the office. Thanks in advance!
Best
Stefan
Sounds like precision error, when things get extremely far away from the origin?
I managed to reproduce the issue here and added this to our system as a bug. I will notify you as soon as we have any progress on this.
Thank you!
It was driving me crazy for 2 days :slight_smile:
Hey Nikolay, was this ever resolved?
Hi @Buck ,sorry for the late response. The internal ID for this issue is VMAYA-9964. It is still unresolved and unfortunately, I cannot give any time frame in which it would be fixed, but I have bumped its priority.
