Physical Camera from perspective
How make VRay Physical Camera from Perspective view ? ctrl+c working only for normal camera. There is a shortcut for vray Phys cam, isnt it ?
create a physical cam anywhere, keep it selected, press “ctrl-c” in the current standard camera/perspective view.
you will have to manually assign the FOV, but then it should be right.
Yeah, this is it, thanks.
the other method is to press ctrl+c while in the perspective view - it will create a standrard max camera, which you can then convert to vrayphyscam.
the fov will be fixed and the same as in the perspective view
