Hey there,
i might have found a new bug ![]()
First of, my specs:
AMD Ryzen Threadripper 3960X,
64GB Ram,
NVIDIA RTX 2060,
win 10,
Cinema 2023.2.2
Corona 10 Timestamp: Jun 20 2023 12:40:33
So here’s whats happening:
When i increase the size of the physical camera in the corona camera Tag (e.g. 0,5cm) and hit render with UHD-Cache on (no matter if still or animation setting) the render is stuck at calculating the cache, black vfb and 100% CPU usage. It’s not freezing though, only when i cancel the render, cinema freezes and is only gonna quit via task manager. I let it run for about half an hour, no change. Image resolution doesn’t matter.
I attached a simple scene for you to try. Just increase the camera’s physical size and hit render.
Thank you all so much for your indefatigable efford, to make corona a great render engine ![]()
Have a nice day,
Moritz
Physical_Cam_Size_Bug.c4d (286 KB)
