Physical Mat and Shadow Catcher
Physical Material on the Sky Object doesn’t work with Shadow Catcher. If I change the Ph Mat with the Legacy Mat it works.
Thank you.
Shouldn’t be using either of those on a sky object - it should be either and HDRI or image direct, or at very worst, a Corona Light Material. You don’t want your sky to have diffuse, reflection, refraction, etc :smiley:
