picked object has no mapping - Corona Scanned materials
I am trying out, for the first time, Corona scanned materials. When I load a new scanned material and click on the “Adjust UV tiling to an object…” button and then click on the desired object, I get a message saying “the picked object has no mapping”. If I then apply UV mapping to the object, I still get the same message. What am I to do about this? I thought the Corona scanned materials did not require the object to have a UV map applied.
Inevitably, the material I applied to the object does not appear the same as the view in the material slot. What am I doing wrong?
I encourage you to read this thread: it deals with your problem:
https://forum.corona-renderer.com/ Issue with UV tiling scanned material #msg211660
Thanks Tom. I read the post, but I really don’t see how it is the same. maybe I am wrong, but I don’t see how this resolves the issue.
I attached a video in which I showed the issue and the solution. See if it helps. In case, you are still getting the same error. It would be best to provide us the scene file by starting a ticket.
https://support.chaos.com/hc/en-us/requests/new
