Any tips on hooking this bad boy up? I don’t have a network and right now I am wireless. I have a data port, but it isn’t live and it isn’t CAT5 or 6. I called an electrition 6 months ago and he said that he could still set me up, but I didn’t follow through. Do I need a V-Ray license for it? How about Railclone and Forest Pack Pro? Hopefully, it’ll allow me to keep the projects moving through my office.
Configuration
DUAL XEON E5-2630v3 2.4GHz, 20MB cache, 8.00 QPI (Eight-Core) 32GB DDR4-2133 REG ECC (8 - 4GB DIMMS)
240GB SSD SATA 6Gb/s
Microsoft Windows 7 Professional Edition 64-Bit
Model Specifications
Dual Intel Xeon E5-2600v3 Processors
Supermicro X10DRT-L
Intel C612 Chipset with QPI up to 9.60GT/S
Up to 256GB DDR4 2133Mhz DIMM REG ECC
1 x Intel i350 Dual-port Gigabit Ethernet Controller
2 x SATA 6Gbps Ports
3 x USB 2.0
1 x PCIE x 16 Low Profile Slot
1 x ASPEED AST2400 BMC
1 x IPMI 2.0 (Intelligent Platform Management Interface v.2.0)
1 x 350 Watt Power Supply
Physical Characteristics
3.8" x 6.75" x 20" H x W x D
I’ll probably need to add more ram, but that might cost a ton, at least it does when calculating it with BOXX. I am assuming I need the same sized sticks for each slot. My main workstation has 128, which I never even come close to needing; I am thinking 64GB.
When you say you are wireless you mean you are connected to the internet wirelessly? it has nothing to do with machines communicating to each other. You need to have wired connection between them in order to have proper speed to transfer assets. You need a cat5 cable, or a crossover cable. You can either use a small switch or plug them directly from one machine to another via ethernet port. Once the other machine can be seen, you would have to access it and install all the software on it. I think for you all the configurations has to be identical between two machines in order for things to work. For the licenses most plugins allow for free network license for rendering. I would suggest reading about each one in their manuals.
Theoretically once everything is setup and same between two machines you can DR with it, or whatever it is you need.
does it run windows? if it does, you can install vnc on it and that is all you need. Your second pc needs to have IP. IP is assigned by the router or a switch on your network. Once it has IP you can use it. But first time you set it up you need to connect a monitor and user keyboard mouse to it I believe.
You won’t need a crossover cable, the NIC will automatically make a standard cable into a crossover as necessary.
BOXX uses IPMI to allow remote management via ethernet. Think of it as VNC or Remote Desktop via hardware rather than software. The IPMI interface will have it’s own IP address and is always available as long as it is plugged in (even if the machine is not booted). It’s more robust than VNC or RD due to this but doesn’t offer anything special, especially if it’s only one machine and it is right next to you rather than in a sever closet somewhere. With IPMI you can essentially watch and use that computer from another PC just like you were right next to it (turn it off, turn it on, reboot, watch windows start, enter the BIOS, etc).
Lastly, you’ll probably need a render node license for VRay, I think the workstation license only allows 1 render node and 1 GUI node and you woul dbe using the render node whener you are using the GUI - double check this.
I was seeing all kinds of prices for the crossover cable. From $300 to $8, so I ordered the 10’ $8 cable. Since I don’t have a network cable on hand, I’ll just use this one.
I will. I have been looking at BOXX for years, but never could justify the cost. Double the stock 16GB of RAM and they’ll charge you grand; what RAM cost that much? All the parts for all these computers come from the same places, so I am not expecting anything amazing. I got it for 1/2 price and the form factor will work for me. It is a 1/4 of my workstations, so it might just help a little.
base on processor it used, should be much slower than ur current workstation. ur boxx machine come with IPMI software? if just distribute render should be no need vray interface license, Railclone and Forest Pack Pro can just install as render node mode.
Yeah, I am assuming it’ll help a little, but every little bit helps. New at $4300 is a bit insane, but I paid 1/2, so hopefully it’ll pay for itself in no time. I’ll no a benchmark when I get it up and running. Who knows, maybe the folks over at BOXX have some magic pixidust they use.
yeah i costed an identical machine recently and it was half the cost they were charging…crazy..must be some reason..there again it reminds me of Silicon gfx back in the day.
I was very close to building a copy of their Render Box, I’ll see if I can find the parts list on my hard drive somewhere - what put me off in the end were my doubts over the noise and heat that’d be generated (as the cooling didn’t look very efficient).
