Pink water in render
Hey guys, im facing this problem. Water is pink no matter what i do. I tried enable caustic and disable and nothing changes. Do you know maybe why is my water pink, it was all good and suddenly became pink.
Best regards
Change the water to a chrome material temporarily and you’ll see what it’s reflecting that’s causing it to look pink
I found , its volumetric material. But why? No pink at all
Do you have a CoronaSky with Volume Effect enabled? If so, does it help when it’s disabled?
There used to be a pink/purple hue to volumetric materials once it’s enabled, no idea if it was supposed to be fixed or not.
@Jahac_oluje
Can you perhaps share a scene file by starting a ticket so we can investigate it further? I will check what can cause the color change.
https://support.chaos.com/hc/en-us/requests/new
Hi @Jahac_oluje
this is a gentle reminder to share the scene.
