Pixel information of OpenEXR loaded with VFB is not displayed.
For example, open Sky EXR of Chaos Cosmos and check it.
Confirmed with V-Ray 6.1 and Stable Nightlies
Hi, thanks for posting. Try to build a scene, render and save in exr. The pixel information is there. If you open just a random exr file that is not saved from the VFB it won’t work and this is expected.
I understand that this is a VFB specification.
But why doesn’t it work?
I would like to find out the pixel float values of HDR images found on the internet.
It won’t work on every HDRI. Actually I couldn’t find a single exr file in our assets that worked. But there seems to be more to it. Waiting on a developers opinion right now. Please have a bit more patience.
It doesn’t work if the exr file does not have alpha channel (which is common for HDRIs). We’ll check if we can change that.
Yavor
Hi @flat , in the meantime if you happen to have Chaos Player installed, you could use that to check the pixel values.
Tsvetan
Helo, development team
Thank you for the information about the Alpha channel. interesting
Ah, there is ChaosPlayer.
And I found that we can measure the EXR Float value in 3dsMax File>>“View Image”.
