Which plants/organics plugin would you recommend to use with vray. Obviously anything rpc related is out of the question! ![]()
Ive been having good luck with the one that comes with max
-dave
i use x-frog
Da_elf: Doesn’t xfrogs really kill the render time though? Or maybe I’m just doing something wrong. The ones I tried are the public plants and I saw a 5 hour (1500x1125) render jump to 10 hours because it would take forever to do the passes and render the xfrog plant.
-Andrew
1st tip with x-frog. never never use the x-frog import plugin to import the trees. import them as 3ds or someother format. the other thing is to make sure to use vray materials for the trees especially for transparency. then also i use my trees as proxy objects. it really lowers the size of the scenes freeing up some ram helping me render faster. thats the only info i can give on them
plants
If you’re looking for trees/plants, the way to go is Speedtree. Pretty good quality and very render times. About $400
good luck
ken z
damm vray handles really bad massive bitmap opacity leafs ![]()
