i guess i was hoping for better performance, ive no idea if there is some issue ive not understood: if i disable caching and hit play on a 4k png sequence, i get 1.4 FPS…
the frames are about 30Mb each… however my drive is a pair of pcie4 ssds in raid 0, sequential reads should be over 10Gb/sec.. theoretically only needs 750Mb/sec for 25fps. pc is a 64 core 3990 with 128gb ram. is there any hope for faster drive reads?
on a related note i get similar speeds when caching… it takes a while to load a 250 frame sequence. In DJV you can set multithreaded caching to use 32 threads and it loads much much faster, but still nowhere near realtime.
