50 passes just color correction with camera raw.
nice , the fog looks a bit too red though..
Nice effect. How dou you achieve it? i was playing with environment override volume material without much success.
Amazing!
Would it be possible to share a quick step by step? ![]()
It looks really nice! Is the colour from the sun or from the volume material?
Yes i agree… could you please explain us how you achieve this beautiful work ?
Thanks !
as always its very simple with corona.
But the most important part is here https://coronarenderer.freshdesk.com/support/solutions/articles/5000534910-how-to-use-subsurface-scattering-volumetric-absorption-and-scattering-
Love it !!
Really great ! I have to test it ! ![]()
Thanks for the tips and setting !
Thanks a lot jetcrow… it help you can trust me !
You can also check “single bounce only” - it should make things much faster with probably no visual difference. ![]()
Interactive mode is very useful when tweaking parameters of fog.
Big numbers indeed… and how far is the sun located?
Thank you for the screenshot!
Hi jetcrow. This is some really great renders. I love the fog effect you’ve created. But… I simply can’t figure out how to make it myself. I’ve replicated your settings (thanks), but I’m not getting anything near your result. So I guess there’s something I totally missed…
Is it possible to get this result (or similar) in the renderer, or is it only possible to do it in post? What element are you using? (tried Volumetric, but it didn’t work for me). Any tips regarding workflow, to achieve this beautiful effect?
I’ll really appreciate any help regarding this “big mystery” ![]()
