Since a new version came out you cannot have same object in 2 phxsources. Would be nice if you can add a check mark to disable objects in one of the phxsources that way you can use those objects in another. I know you can delete but then if i need to simulate fire again I have to add all the objects to the fire phxsource again
Good idea, thanks!
I was just playing and have several sources in scene and wanted to see what each one is doing so this would be very useful.
