Please add a VR camera settings. Like eye-distance parameter and a focus on/off switch.
Thanx
Thanx
Hello, Yuji,
The eye-distance parameter is hardcoded to 65 mm.
The focus on/off switch as well as additional options can be found in Asset Editor’s Settings > Camera > Depth of Field section.
Kind regards,
Peter Chaushev
Thank you for clarifying!
I have logged your request about exposing the focus method (and subsequently the focus distance) settings. Will write back once our developers reach a decision about this.
In the meantime, as a temporary workaround, you can save your scene as .vrscene file and edit its focus_method parameter value (0 - none/parallel; 1 - rotation; 2 - shear) before rendering it in V-Ray Standalone.
Let me know if you need any assistance!
Kind regards,
Peter Chaushev
