every day I have to rename rendered sequences in order to be able to load them into software.
It takes up so much of my time and is so annoying…
“myfile_0001.origRGB.exr” is not readable as a sequence from any software
- even not from your own new Chaos Player!
(or other example “myfile_0001.VRayDenoiser.exr” )
So I have to rename everything with special software, in order that the sequences can be properly loaded into a player or aftereffects or anywhere else.
Hi how do you save your output? On my setup naming is just as you said - > “myfilename.renderelement-name.0001.exr”
What versions of V-Ray and 3ds max are you using.
