VRay: 1.50.00.10915
The batch camera name should be appended to the end of the image filename when there are multiple renderable cameras - resolved.
This has introduced a bug, when using the Render command the user should be able to control the export file name and not have the camera and render layer appended to it. This is problematic with render farms where you need full control over the output name.
If you want to export the scene for different cameras using the -cam option, and the camera name is not added to the file name, then you will just overwrite the same .vrscene file.
Well, i agree with having multi cams in situations and rendering those, but would be handier if it just exported from maya into vrscene,
that way the user has control in maya, now you don’t have that much control over the outcoming file..
Also this person is a windows user, so he doesn’t even have to worry, cause he has a working renderbuffer,
rather have that fixed first before doing that request..
Its easier to make a python / mel script within maya, that exports and saves out , then changing the outputs.
-leave the layer append, makes sense, just masterlayer (confused me) due to → default renderlayer naming
-remove the camera one in the next build please,
reason being: it 's not lowering your render times, i mean exporting a camera is 10 kb or whatever.. (not adding a difference exporting in file or sep)
And if the reason is stereoscopic or multicam its easier to run a script that renames the layers _L and _R, and exports those out, you still have to write Vrscene files,
so will take the same amount of time. (1 per camera, ) also making 2 files, is not that big of a deal…
You have to have this control from maya, so lets say when it renders Images, it just renders images with a folder names L and R. , or Cam1 Cam2 in the render outputs.
(not appending this to the “file name” but doing a directory before as option.
However next to writing “lights” and “materials” as seperate .vrscenes it could help adding a “camera” option in the translator,
this way if your writing everything out, you could make a python compile, and recombine the vrscene,…
This would actually speed up workflow etc, and then the camera export would work and save workflow time.
Lets say if your working with a big team, a layout person could reexport just the camera, and a lighter would have a new update…
We will probably remove the automatic addition of the camera name to the .vrscene file name; if it is needed, one can always include the <camera> tag in the .vrscene file name.
