I set up the Corona High Quality like this but when finished the images still have noise without Denoising.
Anyone please help me
I don’t see any noise in your render. Maybe you attached the wrong image?
Did you try to toggle denoiser on and off on rendered image to see if it’s doing anything at all?
Yes i did it. I will try more with the other denoise options in F10 settings and test with each lightmix when rendering
Thank you so much for your help!
hope to see you again!!
