Please return spinner "Gamma"
Please return spinner “Gamma”, even if hidden with access via maxscript =(
What for?
So more flexibly…
PLEASE…
gamma was removed because it was not working anyway lately, and having separate gamma controls from 3dsmax was confusing. Also removing it speeds up image saving by 100% :smiley:
Personally the separate Gamma never misled me.
About what You?
I think, saving .png, .exr etc… from frame buffer
+100!+500!!
Please turn gamut back in debug menu. Many people always use it in their works. These who don’t use it can simple skip this option. For example, I always use it in the each my project and if this option there won’t be in next releases then my work will become to be very uncomfortable. Does user need a stripped-down tool?
I don’t understand.. why is this not done in Post? why are you tweaking your gamma in the frame buffer anyway?
Anyway, leave gamma out of it, no one needs it :tongue: just to go against the grain! haha
i agree!
because without gamma now need to always do post-processing. Contrast is not as useful for obtaining the desired result.
By the way, maybe just place Gamut into Exposure and color mapping?
ps: As for me I don’t touch default 2.2
Gamma as post-production contrast altering tool is just poor mid-tones affecting curve. I would be vary of incorporating something as confusing as that, since gamma is foremost used for different purpose than post-production inside Render controls.
It could be in frame-buffer, if it would be clearly in post-production section, but rather not in Main UI.
Have a look:
Well and as it is possible to set up materials in gamma 1, no shit it isn’t visible…?
You have probably incorrectly set up 3dsmax - you need to fill 2.2 everywhere and check all checkboxes in the gamma/lut config
Why incorrectly?
According to Your advice I switched off gamma, for operation of VFB in gamma 1.
@ecximer
Why do you need the gamma spinner?
The gamma should be set at 2.2 for work, and if you render in full float you will get an untoned exr image, after that apply your gamma in comp, since you have a full float image you can do whatever you want.
You should not be playing with gamma for correcting the render IMHO, you should get a linear full float image to work in comp.
Master Zap did a great post about this some years ago.
Cheers!
It’s possible to write a lot about gamma 2.2, and that it’s the only one correct. But not everyone works by-design and it’s incorrect to fit everyone in one size.
I don’t work in 2.2 (and ecximer also doesn’t), but now I have to change my workflow. For example, the latest gif I posted above is made in gamma 1.4, and I can’t achieve the same result in latest builds. That leads to the need of post-processing and excessove manipulations… what for??
It’s much simpler to leave the switch in settings, and don’t make life harder for users. That would be their choice in which gamma to work.
But please don’t tell me that it’s only correct to work in 2.2 - there are many opinions about this.
Our betatesters group is discussing this question quite frequently, and there is still no consensus about this. But anyway, it’s the final result what is important, and not the correctness of it… the most important is the result - that’s why I ask to return the gamma in setting.
And newbies won’t find it anyway. Btw, other renders all have gamma settings, isn’t that proof enough?
kregred, +1
for me, “work in gamma 2.2 only” = “warm lamp sound”
Ok, I understand you have different workflows, but then why don’t you make yourself a macro script or a script that enables you to change the gamma in a general way? Not just for corona but in max in general.
Because now you can change your gamma settings in max, I understand it’s difficult to change it now because it is inside settings, but you can do it.
I’m out of my computer until late next week but I’ll try and check if I can do a script that enables you to change the max gamma when you want.
Anyways as Keymaster said, handling the gamma himself makes the file saving slower (or the framebuffer handling, I’m not sure about what was slower), but you can handle it from max.
Merry Christmas to everyone who celebrates it!
Cheers!
I agree with Kregred! I don’t understand how the gamma parameter can spoil the render.
Many who heard about it (from future customers) write to me that a very saddened by this fact …
The problem is that gamma is just not an artistic control tool - it HAS to be used in some way, otherwise your workflow will be ruined. Yes, jpegs have to have 2.2. Yes, you can use 1.6 to get more contrast. But this is deliberately lying in the image format. It will eventually cause troubles.
Example1: HDRs vs LDRs. Say you apply gamma 1.6. Then one day you want to save an EXR. EXRs are without gamma - so do you leave gamma to 1.0? That would erase your gamma postpro effect. So actually you would need to apply some gamma <1.0 to get the same effect for EXRs as applying gamma <2.2 for JPEGs. This gets ugly quickly.
Example 2: Misinformed/outdated tutorials on the internet claim “mac has gamma 1.8”, or “LCD monitors have gamma 2.4”. While that may be true (in some totally irrelevant sense), it may fool people into thinking they should change gamma in every scene to make it “more correct”, while in the reality, the way 3dsmax is implemented, ONLY 2.2 is correct (because it specifies the gamma of the output color space, not any hardware - OS handles that for you).
This is using tools outside its intended purpose, as hacks. It caused some bugs in Corona with 3dsmax, with different frame buffers and render elements, so I have taken it out. Plus to control gamma, I had to actually first remove the 3dsmax gamma, then apply Corona gamma, resulting in longer save times.
Now, I am not saying some gamma-like control could not be added - but it should not be named gamma, but rather something like “midtone balance”, with default 1.0, applied both to HDR and LDR indiscriminatively.
I first encountered this gamma stuff when doing this image:
[upload|4oCHxHGl8124FfQCHBsaMw==]
I was trying to match my real world compter. But for some unknown reason, I was unable to get any light inside of the case - either it was too dark, or everything else was overbright. I tried different tricks, invisible lights, removing glass, increasing GI amount > 1.0 (gotta love vray :wink:), but nothing looked remotely right. Then I discovered the linear workflow tutorial, set it up, and BAM, everything was exactly like in reality. Of course, I thought, everything around was too washed up, unrealistic, etc. I wanted to go back to 1.0, but I had to stick with gamma 2.2 to match the reality inside the case. By the end if the project, I would never go back to 1.0 workflow.
I know I won’t convince you, nobody is obliged to use only physically correct workflow - but IMHO you cannot go wrong by sticking to it, and deviating only as little as possible ;).
