Plugin dialog box: how to remove plugin.
When opening a file in Viz 4 (has only been opened on Viz4) a dialog box comes up with:
Missing DLLS : FileName: boolcntrl.dlc Class: Boolean Controller
Is there a way to remove this? Im not sure what object it is referencing, my assumption was well a boolean object.
Any help?
Thanks.
Arkitec
you just have to reinstall the boolcntrl.dlc in your max plugins folder.
is that a default driver? I dont have any special drivers for boolean stuff, just the viz default…
Arkitec
I have noticed since this thing pops up in the last three days. Since then, when I create a panorama out of Viz 4 it crashes. Now, with that said, the panorama renders fine, its on export to quicktime that it crashes.
PLEASE, any help.
I am about to try using the panoscript posted.
Thanks,
Arkitec
Well,
I just “repaired” the installation of viz, hoping it would add the boolcntrl.dlc back into the stdplugins folder and no dice…I also thought my file is crashing cuz i realized I upgraded to the newest quicktime 6.5.1.
Still no dice, panorama crashes. I am able to export as a cylindrical, or spherical image but as soon as i export to a quicktime, viz comes back with an error…
Im totally frustrated as you can see…three post in an hour…
Arkitec
