PNG always gives a black background
I have a problem that I cannot solve easily as I am still quite new to Corona.
I would like to output the fronts of a piece of furniture separately as a PNG without a background.
However, when I try to output it with the Render selected Mixel mask (Include List) function, it always gives me a PNG with a black background.
There is a possibility to output a mask with Corona and then cut it out in Photoshop with the base image.
But I don’t want to do that because there are many images with many variations. So it should be possible to directly output a PNG with only the front from Corona.
Here is the base image, and this is unfortunately always the result.
Here is The Basic Image
Thanks for any help
Regards
Dennis
Are you also new to Cinema 4D? Did you turn on the Alpha Channel option in the Render Settings?
Perhaps you can share a test scene for us? It should be rather simple to do however.
