So, I have had discussions on this topic in the past, but I can’t find them unfortunately…but I’m either amazed this hasn’t been fixed, or I’m missing something…
I’m wondering why I still have issues with losing 90% window glass reflections when I save a Corona Render to PNG. If there is only sky (and no geometry) in the background behind the glass the PNG is saved with basically no reflections in the windows…
Please see attached screenshots for an example. All materials are from the corona material library (the glass has 5mm thickness), the scene is using only corona sun and sky.
As you can see if I save out a JPG the sky is visible and the reflections are strong. If I save out a PNG and put the same sky in the background (in photoshop) the reflections are almost completely gone…
I don’t want to have to save out the reflection pass every time and do this is post, I feel this should work as expected properly. Am I missing something?
btw the I’m saving out from CIE. Not the VFB.
