PNG Opacity
Dear Group,
Does anyone here know if VRAY/Max can read the opacity that is embedded in a PNG file? I tried using the technique prescribed here but it didn’t work:
http://area.autodesk.com/index.php/forums/viewthread/17192/
Here is a view of the PNG file that I tried this technique with:
and here is the result:
As you can tell, something is very goofy here. Does anyone know if it is possible if the PNG opacity can be used because if not I will be required to spend an inordinate amount of time creating separate alpha maps, time I would rather spend modeling and rendering.
Of course you can do that; you need to use the map twice - once for your diffuse color slot, and once for the opacity slot with the RGB color taken from the alpha channel. Of course, this is not specific to V-Ray in any way - you use the same approach e.g. with the scanline renderer.
Thanks,
What they didn’t (explicitly) say to do was that the Mono Channel Output should also be set to Alpha. When I did this, the results were as I expected.
