PNG render output no longer has transparency!!!
not sure if this is intentional but theres no transparency when i save my renders to PNG.
why is that???
Re: PNG render output no longer has transparency!!!
oh really!! are you sure with that FA? ok i will follow this thread, since im thinking to take the plunge or not…
Free Agent
Just did a test (to make sure!) and transparency is working for me, so not sure whats causing your problem.
David
In the original release we required that a Color output channel and an Alpha channel were active at all times. Now we don’t, so it may be possible that your alpha channel has been disabled, which will prevent vray from saving that information within the file. Thats my only explanation, and I haven’t seen an alpha not be saved.
