PNG texture transparency support?
I can’t see transparency coming through Enscape, using materials in Revit.
My texture map is a PNG with transparency (alpha mask).
Is it supported by Enscape?
thank you
@Giovanni , that should be supported just fine; can you kindly send me the .png file and a screenshot of how you’ve setup the material in the Revit material editor itself?
here is a screen capture with some examples…
Also, I have included the two PNG used in the Revit material…
Hi @Giovanni , it looks like the link to your third picture doesn’t work. Would you please be so kind as to post the screenshot again?
In the meantime, I have tested this using the PNG files you provided. Are you adding the image file as a transparency image in the Revit Material Browser? I created a default material and added the second of the PNGs you supplied.
This is the result I got; is that the effect you are trying to achieve? You can play around with the settings to make it more or less transparent.
