PNG texture transparency
I fail to generate a grid transparency to render that material placed as PNG extension receives the texture plane behaves as a solid and allows light to render Y need help and sorry for my english ,it is very bad. Thank you
you have to add a transparency map appart from the png. png images will always render as a normal difusse unless you also add a transparency map, right next to the difusse.
Probe thanks what you said and it worked as I needed was to activate the box to use the alpha image. a hug
