Hi! I used to be able to render textures that have PNG transparencies (the PNG file created in photoshop has areas masked out, or gradients that go from transparent to opaque) in SketchUp, and have them translate in Enscape. For some reason, the scene I am working on isn’t doing it for some reason. It’s been a while since I’ve had to do this. Am I missing something? See screenshots. Also attached is the PNG gradient I’m trying to render in Enscape.
Welcome to our forum!
I quickly tested the image file and had no issues, make sure you have checked the Transparency box in our material editor.
If that didn’t help, could you perhaps share the material settings you have as well so we can see what may be the issue?
Thanks in advance!
