Poblemas to preview material , Poblemas para previsualizar material
Well when I apply the material to any model in the material editor of the v-ray I see in black but when I render if that I look good, but if I can not see how they will be before the render is a mess since I can not fit at all because they will not let me edit the information entity measures and earlier if he could do it perfectly.
The version of SketchUp is the 7 and vray is 1.48.66 and I have the win7
Here you put the video pra you to see a snapshot of what happens to me.
En Español:
Bueno cuando aplico material a cualquier modelo en el editor de materiales del v-ray se me ven en negro pero cuando hago el render si que se me ven bien, pero es que si no puedo ver como van a quedar antes del render es un lio ya que no puedo ajustarlo de ninguna manera porque no me deja editar las medidas en informacion de entidad y antes si que podia hacerlo perfectamente.
La version del sketchup es la 7 y del vray es la 1.48.66 y tengo el win7
Re: Poblemas to preview material , Poblemas para previsualizar material
Version 1.48.83 has just been released and it fixes many issues.
Inglish:
I forgot to say that and upgraded to the latest demo version and the problem persists
Español:
se me olvidaba decir que e actualizado a la ultima version demo y persiste el problema
correct, this issue has not been resolved in .83, we are working on another patch that will fix some more issues before we take a break from SU development. The issue is that the image you are using for your texture, isn’t being found automatically. If you look in the V-Ray material editor, you should see the path it’s trying to use for that material, verify the image is located at that path, or change the path so it is correct.
Inglish:
looking for texture if it works, what happens is that you used to automatically and not now, but hey, I’m more relaxed knowing that you are working on it.
Espenich:
buscando la textura si que funciona, lo que pasa es que antes lo hacia de forma automatica y ahora no, pero bueno me quedo mas tranquilo sabiendo que de que estais trabajando en ello.
Yes, we believe that we have it resolved now in our development version, which will be a beta version soon. Sorry about the headache :-\
Español: por el momento puedes usar esta opción:
English: meanwhile you can use this option:
regards! :wink:
Español: Muchas gracias, la verdad que me fue de ayuda :wink:
English: Thank you very much, the truth that I was helpful
